Well this what i found out, i started by pulling out the cps unit, pulled all the plugs out laid them accordingly to firing order witch is 1-6 3-4 2-5 disconneted the fuel relay and spun the gear on the cps and found that the wiring to the coil for 3-4 and 2-5 was backward (thanks to tweaked performance) 1500.00 u would think u would done it right just saying, that why when I pulled spark plugs 2,3,4,5 was wet with gas, next was to check the fuel inj harness also wired backward was 5 and 6 inj plug tested with a noid light and switched it around thx god they gave enuff wire for that, again thx tweaked performance, so tmr i will put the motor again and see if she will start.
