So I'm new to supras picked up an 88 7mgte for 1500 thing was a wreck, I've done alot to it but I'm having problems previous owner had head gone through put a 3 layer steel gasket and arp bolts I added new manifold seals on intake side and new radiator. The exhaust manifold has 2 to 3 bolts stripped out and I will be putting inserts in Tuesday. But as is the boost gauge is reading vacuum of 20 psi and no boost when giving it gas so I took off the aftermarket bov and I don't feel hardley any air flowing thru the tube, the turbo has no shaft play at all but I can't tell if it's functioning properly, I don't know how honestly, it also has absolutely no power and over heats I made sure there are no air bubbles in system and it currently has no thermostat waterpump is flowing and fan works could leaking exhaust manifold on a turbo car cause both those or do i have two separate problems.. Help!
