Fresh build. Starts fine, idles great(no surging, sputtering). Give it throttle it bogs and then recovers, but doesnt rev freely. It acts like afm or tps. Uplug either one, idle changes slightly but still bogs with gas. replaced both the tps and afm, still no dice.
mods are afpr, t4 turbo, bigger spearco replica, hard pipes all else is as stock as i could leave it for the break in.
only code coming up is code 11. Checked all grounds, and there is power to the batt teminal and b+ and b1 (voltage on these two terminals is about .3 volts lower than the batt voltage) Next thing i'd like to do is run a fused wire to the B+ and b1 and see if i can get rid of the code 11. what is the best place to tap into these wires? Cut the wire a few inches behind the plug?
Any input or suggestions is appreciated, this is driving me bonkers. I dont want to let it idle much more the time to seat the rings is fading quickly.... Thanks!
