I thought I put that in my original post, CEL isn't illuminated, I jumped the terminals when the problem began, and I didn't have any. Ill check tomorrow afternoon and see if I have any, but the last time I checked I didn't.
jetjock;1795388 said:^ Finally. Only took 18 posts.
OP: It's not your igniter...
IndigoMKII;1795485 said:Wouldn't the car have to run for a set time above 200 rpm for the CEL diagnosis to do any good?
jetjock;1795656 said:Depends on the code but in most cases no.
OP: Reset the ECU and see the 11 comes back. You may have other codes but they won't be displayed as long as that one is active. If it comes back it'll need to be fixed.
DylanB;1795998 said:...The CEL just flashes when I turn the ignition on with the terminals jumped...
JStoked;1796071 said:No code 11 would not cause yor prob as jj already stated. Now on to your lines. Make sure they are all good!!! When you did the headgasket all coolant lines, vac lines and any other hosing that you can. Not trying to be rude but just letting you know from my own personal experience.
