7mgte stalls after high boosting
supramk3
sleeper
Apr 6, 2009
32
queensbury
Hey guys whats up. I have a problem i just rebuilt my 7mgte and modified a few things I have a hks 2.5 mm head gasket, arp bolts, t04e turbo, custom intercooler, custom pipping, 3" exhaust, and many others. But my problem is when im reving the engine in neutral after the R's go down it stalls, I checked the bov (which is recirculating) and used some soap and water to check for leaks and cant find a thing. Was working fine till today.... Thank you
BOOSTEDSUPRA
THE DRIVELINE GUY
Jan 4, 2007
308
turlock, calif
your dash pot is most likely not working correctly. throttle is probly "snapping" shut and will die everytime. there are a few very good threads on here as to how you can adjust this, and even upgrade.
89supra7mgte
797
colorado
try using some carb clean to check for leaks make sure you are nowhere near the afm though, it will cause damage. check around your intake manifold, tb and iscv
