Ok, I Had A Intake Leak And That Was Fixed. A New Gasket Helped.
New Problem
The Car Idles At Midway Betweeen 0-1,000RPM. Then It Starts To Rise A Little Bit Below The 1,500RPM Mark And Then Drops. Then It Keeps Doing That. The Car Has No Exhaust, Just A DownPipe And The Wastegate But The Nipple Is Not Installed On The WasteGate. That Will Get Installed Tomorrow Since I Have To Drill And Thread A Hole On The OutLet Pipe Of The Turbo For A Nipple. Right Now, The Car Has No Air Filter On, Just A Mesh.
What Do You Guys Think Is The Problem? I Don't Have Any Vacuum Leaks Because I Smoke Tested It. Ask Any Questions You Have. No "Check Engine Light" Either. Thanks, Andy.
New Problem
