7MGTE Rebuild Cost
Doward
4,245
Alachua, FL
Ahh! Labor is where you got killed.
I always do my own assembly and labor, wherever I can. For one thing, makes it pretty easy to know who is at fault, when something goes wrong :D
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
The head is where things can get real expensive real fast.
sufacing
Valve job (cost per hole X24)
valves (pending how yours look, Ferrea are much nicer than stock)
springs (probably want to replace the 20yr old OEs)
setting the clearance - might need to buy additional shims (not cheap)
retainers, locks, etc
Do it once and do it right. You won't make any power (and the motor will run poorly) if your valves are leaking at the seat.
need new tires
rubber slinger
Nov 10, 2005
173
Dayton,Ohio
my built motor is running me in a the neighorhood of 4500-5k.
includes
je pistons .20 over
crower rods
ferra valves 1mm over
com cam springs
clevite bearings
all machine work
full port and poished head(done by me)
poished crank
so it aint cheap but pay to play.
i plan on 700 rwhp out of a t67. then a fun gt35r so i can drive it
-shane
Doward
4,245
Alachua, FL
sufacing
TRUTH.
You can EASILY sink another $3500 into the head! I'll be doing a resurface, basic port/polish, a light bowl blend, and the 975 springs for now. Depending on how finances look, I might toss cams in there right off the bat, but we'll see :D
bwest
May 18, 2005
502
HippieTown, CA
What these lists also don't take into account:
Clutch - if the motor is out, do you really want to leave that old clutch on? or replace it while everything is apart? Would suck to do all that work and then have it slip as soon as you turn the boost up.
transmission - again, the hard work is done and its out of the car. at least inspect it.
injectors - at a minumum clean them (~$90 at www.cruzinperformance.com)
gaskets, hoses, etc., aren't cheap for the real Toyota versions
re-wire your knock sensors (or atleast inspect the wiring) Save a lot of hassle later.
There is alot that goes into a rebuild besides pistons, rings and bearings. If all your other stuff has been recently replaced, then you probably don't need to do it again. If not, add it to the list. Not trying to discourage you, but there are a lot of costs that go into refreshing an engine and then making sure you don't have any problems when you get it back together.
Always plan for the unexpected.
Doward
4,245
Alachua, FL
Yep, that list of mine is the shortblock online.
Things not listed:
TEC-2
NM ShortThrow Shifter
5 Speed Swap
6 puck clutch setup
12lbs flywheel
Tubular T4 header
PT67
680cc injectors
Walbro 255
etc etc... I really don't want to know how much I've spent on this car :D
MA70Snowman
374
San Diego
ARRRRRGGGGHHH thats sooo depressing. luckily i'll have banked after my deployment. I agree with everyone else... do it right the first time. and by do it right i mean "balls to the wall or not at all" build that sucker so you can throw a nuke at it and it won't even shudder. I don't care if its all stock bolt ons as long as i have the potential to throw whatever i want at it and not worry.
After the last meltdown here I came close to parting it out and had someone interested in the Head so I added up what it owed me and it's safe to say I was shocked ;) (I have part price deafness when shopping for a build)
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
lol yeah no kiddin, my mom thought i was nutz, and my dad knew i was one of his..
i dont even say to my friends how much i have in my motor, i just let them know the car is worth around 10k lol
MRSUPRA
838
Maryland
My build cost me about $5200... The built shortblock with almost everything replaced was $2900, and the built head with oversize valves was $1900. Plus the 264 cams added $525.
