:cry:
Maybe they will know how to fix this.
:3d_frown:
Codes.
I have a brand new LEXUS AFM. It worked great before I installed the turbo kit, took it for a 20 minute drive.
It was hitting fuel cut aggressively.
The turbo is facing upwards. Problem?
The Venom Injectors 550cc bad?
Misfire/will not speed past 3500rpm.
As soon as boost goes from -20psi - 0psi boost, the engine sputters, will not accelerate.
I can go above 3500rpms in neutral and park.
:3d_frown:
Codes.
- 24 Intake air Temp Sensor Signal
- Diagnosis
- Open or short circuit in intake air temp sensor signal (THA).
- Trouble Area
- Intake air temp sensor circuit
- ECU
- 31 Air Flow Meter Signal
- Diagnosis
- (7M-GE) Open circuit in VC signal or short circuit between VS and E2 when idle contacts are closed.
- (7M-GTE) Open or short circuit in air flow meter signal.
- Trouble Area
- Air flow meter circuit
- Air flow meter
- ECU
- 34 Turbocharger Pressure
- Diagnosis
- The turbocharger pressure is abnormal.
- Trouble Area
- Turbocharger
- Air flow meter
- ECU
- Intercooler system
