7mgte i have a question
yotasupra3
62
OMAHA
ok im doing a swap to a 88 turbo supra had a bad motor i bought a motor for it but it was out of an 89 with the gray plug harness, my question is is the wiring the same on both harnesses on the body side i have the 89 ecu, the plugs plug in to it but there is one extra plug and it doesnt look like the wires are in the same spot if anyone can help that would be great thank you
shaeff
Kurt is FTMFW x2!!!!
11
Around
Punctuation. Use it!
Now that I've got being an ass checked of my "to do" list for the day. Read on.
You stated that you have an '88 Turbo Supra. Use the engine computer and wiring harness from that chassis on the new motor. It'll all plug right in. You will have to swap a couple sensors where the plugs changed in '89, but it's all bolt-on/plug and play.
The wiring harnesses are different, and are NOT interchangeable. Don't try to use the '89+ gray plug setup on your car, because it just won't work.
suprastroker88
Supra Tuner
Jul 16, 2008
453
Bay Area, CA
The guy that swapped in the 1990 7mgte motor into my 1986.5 7mge chassis used the 1986.5 wiring harness. He just said that its ghetto rigged. Which harness would fit right without me having to chop it all up and ghetto rigging it?
shaeff
11
Around
Use an '87-'88 Turbo (yellow plug) harness and ECU. It should be nearly plug and play.
