What is everyones opinion on the stock composite head gasket and retorqueing the stock head bolts? I figured that toyota made the supras with the torque specs at 58 ft. lbs which is the lowest i've seen in my life for heads to be torqued at. Personally i've read forum after forum about torqueing the head bolts to 75-80 lbs on a composite gasket but in my opinion that would squash the gasket way past the normal squish rate. The head bolts i feel aren't a problem because metalurgy test that i've read showed that they were as strong as the 2jz's head bolts. I feel that most supras went over 100.000 miles with the factory torque specs at 58 ft. lbs. I will give the benefit of the doubt and say more like 68 ft lbs seems sufficient to hold the gasket better and not exceed the squish tolerances. Any opinions on this well debated subject? :nono:
