Ill try to be as short as possible...
91 supra,manual, turbo, 550 siemen injectors, aem wideband, apexi neo, aeromotive FPR, upgraded ct26.greddy profec spec2 11.5psi About 2k since motor was put together.
This is a buddies car that I work on more then I would like to. He has an NA that I rebuilt that was a pain and it has never came back. I seem to be fixing the person who put the motor togethers shortcomings, Most issues are pretty straight forward, I have replaced all the gaskets on the turbo/exhaust side because whatever cheap gasket kit they used it, each one is just blowing out. So I did them all in oem gaskets, including EGR cooler gasket. No problems so far. Now to the current shituation.....
The egr gasket and the gasket between lower plenum and egr blew out. The injectors were leaking and so was the fuel dampner. So I ordered all factory gaskets and slapped it together, alot better then it was. Upon first start it seemed like it had a crazy vacuum leak and wouldn't idle. So held idle about 1500rpm for a little while it warmed up and bled coolant. And I know it seems whenever I reset ECU(unplug battery) It takes a bit for it to run right. Has to learn things I guess. So took it for a drive up and down the mountain near me and it ran better then I remember. Parked it for a few days at the place I do the work at until I could pick it up. Drove it to work and about half way there it started hitting fuel cut and warning me of overboost at about 10 psi... and running funky...pulled over..made sure I didn't blow a intercooler hose and all was fine. Restarted car and switch boost contoroller from high boost to low boost and back. Ran fine all the way to work.
Left work...got on freeway with a heavy foot, Started hitting fuel cut and low boost again and then check engine light. Code 71. Got to my buddies house. Did a little visual inspection cause motor was hot. Pulled efi fuse for a min. Restarted waited ten minutes, test drive...Car would not idle. Whenever throttle was closed car would die. AFR was around 13's when under boost so no bueno. Limped it home and after having about 30 minutes to check it out after work or so the last week... I found a vacuum leak to the VSV for the EGR(explanation for code 71) and a kinda big boost leak to the coupling to the intercooler on the cold side. I used a smoke machine to do the test cause even with nifty use of a rubber glove and duct tape for the turbo inlet I couldn't get it to hold a seal with the air pressure test. I tested the intake with the smoke machine in the brake booster line and covering the throttle body and found the VSV line and the actual egr leaks through the diaphram a little bit. After reading that might be normal for supras??( see below) Tested the cooler piping with a pvc setup and glove and duct tape. Found the boost leak at the intercooler and nothing else. Fixed them both...Still runs like shit. Seems to be worse.
Fuel pressure static is like 50 and under vacuum is 40. Which I think is to high, but he said that is how it was tuned...I adjusted it per the TSRM and no change
I tested the egr off the car and the diaphragm held vacuum. But when I (should've seen me doing this) plugged all the ports and supplied vacuum to the diaphragm and put the smoke machine in the head side of the EGR and smoke came out of the holes that are on the bottom of the diaphragm. Not alot but I don't think it is suppose to.
I don't think I forgot anything. But any helpful hints from someone who know or has dealt with this motor before on other things I should check I would appreciate it.
Going to check the IACV tonight as far as operation goes.
