My engine harness is a little chewed up. it is missing the check connector, noise filter and injector resistor plugs. I am assuming that i don't really need the check connector and the wires can be traced back and removed and shrinkwrapped. The noise filter I have no idea what it does. some sort of voltage stabalizer i'm guessing. As for the injector resistor connector, i don't even ahve a resistor to plug into it and am thinking of using radio shack resistors. I just need the correct resistance and wattage.
The difference between hight an low injectors is around 10 ohms (12-13ohm and 2-3 ohm). For the wattage (P= V^2/R) I get 12 watts. That will be at 100% duty so i'm guessing a 10 watt will be fine.
I guess what all this means is i need an opinion on whether or not I...
1 Need the check connector
2 Need to hook up some sort of noise filter
3 Can wire in 3 10 ohm 10 watt resistor instead of the resistor pack.
EDIT. In hind sight, it would be easier if someone knew the resistance values or could measure them for me.
