7mgte harness
gte
14
Hamilton
My engine harness is a little chewed up. it is missing the check connector, noise filter and injector resistor plugs. I am assuming that i don't really need the check connector and the wires can be traced back and removed and shrinkwrapped. The noise filter I have no idea what it does. some sort of voltage stabalizer i'm guessing. As for the injector resistor connector, i don't even ahve a resistor to plug into it and am thinking of using radio shack resistors. I just need the correct resistance and wattage.
The difference between hight an low injectors is around 10 ohms (12-13ohm and 2-3 ohm). For the wattage (P= V^2/R) I get 12 watts. That will be at 100% duty so i'm guessing a 10 watt will be fine.
I guess what all this means is i need an opinion on whether or not I...
1 Need the check connector
2 Need to hook up some sort of noise filter
3 Can wire in 3 10 ohm 10 watt resistor instead of the resistor pack.
EDIT. In hind sight, it would be easier if someone knew the resistance values or could measure them for me.
gte
14
Hamilton
Some one has an injector resistor they can ohm out for me. From pin 2-1, 2-3, 2-4, i think they should all be about the same.
