7mgte going through the gears.
mk3tattoos
1,104
Bremerton, Wa
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
could use a deffinate lean out on your safc. Noticed your 10.2 afr at 4500 -5000 rpm under full boost. Overall nice setup so far, just a little more tuning and you will be there ;)
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
If you still have the heat shields for your turbo you should put them back on. The ic pipe going over the exhaust will run into heat soak very quickly without them. Also reflective tape on the underside of the IC pipe will help further.
mk3tattoos
1,104
Bremerton, Wa
the heat shiels would not fit onto to new down pipe. and i polished the pipes to help with the heat but i think i should still do the tape, and thanks for the advice!
mk3tattoos
1,104
Bremerton, Wa
3tc power;1333944 said:
nice pulls bro.... car sound nice
thanks alot, got to test the water"s on th freeway with a realy nice right hand drive skyline R34. my xtd cheap clutch is no longer holding the power. So i had to race him in 5th gear for the most part keeping the runs from 80 to 130. i beat him every time or would be behind him and letting off the throttle:biglaugh: lots of fun.
