7MGTE EGR Valve Removal
88-7MGTE
Hey Guys
I would like to remove EGR valve from my engine. From what I know this is vacuum controlled system not hooked up to engine computer diagnostics.
So if I remove those vacuum lines and put a cap on EGR plug coming out of intake manifold will that be it or It will screw up something else. Any suggestions ?
Please help any input will be appreciated.
Thanks:1zhelp:
Dunckel
2,949
Spokane, WA
i got rid of my egr stuff a couple years ago. charcoal can as well. car still runs great. my .02
Bishop92t
773
USA
www.ma70.com
So long as your car isn't a California model you can remove the EGR with no engine codes. California models have an EGR exhaust gas temperature probe that the ECU checks. A rheostat (or resistor) in it's place can make the engine code go away and with no problems to the engine. I forget the exact value, 10k comes to mind but I'm not 100% on that.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
removing the EGR will likely cause your EGT's to rise. Most of the guys on this forum that I respect say there really is no good reason to remove it. About the only reason I can think of to remove it entirely from the system is if its not functioning correctly and you cant afford to fix it.
Blackfin
Beach Bum
Jun 16, 2005
205
John's Pass, Florida
Please support this. I removed my EGR cooler and the EGR. Not saying it was the right or wrong thing to do. I just want to know how it raises EGT's and by how much.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Cant tell ya off the top of my head how much. But cooler exhaust temps is a good thing. Im sure the search button right up there in the header will yield some results.
Blackfin
Beach Bum
Jun 16, 2005
205
tte
Breaking In - in progress
Northern California
Hmmmm 2 years back I removed my EGR and my ecu did not throw any codes.
Cheers,
Roy
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
88-7MGTE said:
i guess it wouldnt hurt to clean it and slap it on back thanks guys
i'll do a chek if the temp drops with the egr when im done with my build
you may not notice the water temp change, I was refering to exhaust gas temps. that doesnt necessarily correlate to higher water temps. Just do some research. The EGR was put there for a reason.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
this is the reason i am removing mine. it broke, and i do not simply want to deal with it no more.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
88-7MGTE said:
mine 88 does but i dont know what year is the engine because i swapped out the engines 3 years ago, and mine does have an egr
All models sold in US had EGR. The 89+ California models had a sensor that would trip the check engine light if EGR was removed.
