IIRC, Reg Reimer (Who is super conservative with his builds/power) ran his '82 GTE with a stock shortblock, stock head gasket, stock head bolts (Torqued to 72 ft-lbs) and an HKS turbo with intercooler up to 21 lbs boost when testing the limits of the Lexus/550 upgrade. It's a given that all of these components were good as new (Or better) when he did so, but I'm positive that he'd never have done so if those components couldn't take it. It's also safe to say that those components weren't tuned to make the best possible power, but instead were in the safe "pig rich" configuration, but I still remember that being near 475 RWHP.
That said, I think that it would depend on how confident you are in the components and the build. The OEM head gasket will do fine if you keep it away from detonation. Similarly, the OEM pistons will also be fine. Get "incipient knock" however, and it's time for a teardown. Forged pistons and a MHG will only buy you a little time with the same conditions. Keep the AFRs in the safe zone, and you'll be as good as your build.
