i have a 7mgte with 020 wiseco pistons. there is a spun bearing and im going to send the block to get machined. The pistons were in the car when I purchased it and this is the first time i will be tearing apart the block. Now im not sure if there are rods in the block, but i wouldn't understand why someone would put 020 pistons and not aftermarket rods. Im planning on getting a Master power T70 turbo and i wanna know what are some good ways to build a powerful reliable block. Im looking to stop around 500- 600hp..
I was told about sharp edging the crank?!?!?! Are there aftermarket (lighter) cranks? Other than pistons and rods is there anything else that can be done to the block other than going with a bigger piston?
I didn't spin the bearing and that pisses me off in its own right, but at least i can build this block the right way and know exactly whats in it.
Thanks for all your help & input......
