7mgte 540rwhp 560wtq
Beals
JZA70 TT-R
Feb 3, 2009
591
Alberta, Canada
I think with cams you'll notice the biggest gainsfor. I;ve always liked smaller turbos for quicker spool then larger turbos for more horsepower.
ttsupra2503
6'8 BC Giant
Feb 28, 2012
146
Kelowna, BC
Personally I would suggest cams, valves, springs, retainers and the port and polish on the head as the next option to get more power. It looks like its about a 1500 dollar upgade if you find the right places and do a lot of the work yourself. The Brian Crower Valve Sping and TI Retainer kit is $350 bucks online and the Brian Crower 264 degree camshafts are 620. The valves are about 220 each side, intake and exhaust. Or if you want it all done ahead of time the head is 4k.
All in all, it will help your motor breath better. Just wondering, are you running 2.5" piping through the whole intake piping setup?
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
where the hell are you finding BC cams for 620?!? Cheapest I've found is around 700...
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
jonny87turbo;1879043 said:
Its comp turbo with supra sports exhaust housing.. I would say 4800 to 5000 I see about 30psi.
That's the issue.. COMP turbo.. Get a PTE 6466 & see the huge difference in power you will make.. BUt still great number!!! Good job..
8,898
Devin LeBlanc;1888901 said:
On stock head, cams, and valves with no port work at all. Just valve springs and retainers I made 600WHP and 560tq At 28 PSI on a T3 adapted stock cast manifold with a 67mm.
Just think about what a baller you would have been if you did bowl work.
