I have a 92 supra with the na-t motor in it everything is from the gte but the block and pistons. I have it running 9psi it runs good until 5psi then feels the same til 9you it feels like im hitting a wall any ideas?
it runs better at about 3/4 throttle then it does at wotmikehockenberry88;1863393 said:I have a 92 supra with the na-t motor in it everything is from the gte but the block and pistons. I have it running 9psi it runs good until 5psi then feels the same til 9you it feels like im hitting a wall any ideas?
mikehockenberry88;1863393 said:it feels like im hitting a wall any ideas?
mikehockenberry88;1863501 said:The engine dosnt wanna just shut off. Factory turbo and i have a 255lph fuel pump and a aftermarket intercooler.
IndigoMKII;1863716 said:If you have a higher flowing fuel pump you need to drill out the jtube and probably get an AFPR. Chances are that at full throttle your car is running too rich and bogging itself out.
