yes the picture with the black sharpie writing on the coils. sorry about the double post, not trying to confuse you.
he is talking about the grounds on the lower right side of the intake, near where the 2 half's of the manifold meet. There is a grounding point. not sure if the ECU is grounded there but its a good place to check.thenderson2011;1844069 said:So which of the terminals do I use to check the ECU?
jonahs_supra;1844076 said:http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=149
B is the grounding spot
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=151
now read this
jonahs_supra;1844093 said:lol just wanted to be a smart ass lol
oh and make sure the ignition is turned the on position when testing..always remove ground cable from battery when removing or installing ecu connectors
once you have confirmed you have the correct ground and voltage
then i would suspect your cps is not timed correctly(common issue people have a hard time correctly installing it)
i have not yet removed or installed a cps
but if you use the search button or google then im sure theres something out there with the info you need
jetjock;1844154 said:No ECU power = no MIL or codes. Just sayin'...
