im new to the mk3 world and i have an N/A 86.5 and i was just wondering if there are any odd or weird problems with the 7mge that can be moded and fixed to make the engine last longer or gain a little power.
thanks, wilcox
thanks, wilcox
Wilcox;1911851 said:ya already encountered the hg problem, did a hg and torqued them to 76 lbs. thanks for letting me know about the oil issue, and where do i get red toyota coolant and how does it compare to prestone or dexcool?
Silver MK3;1911910 said:I use Valvoline Zerex G-05. Its basically the same as Toyota Red, and it is cheaper. A lot of very knowledgeable people here run it also. Just make sure you flush out whatever coolant is in it now so it doesn't mix with the new coolant and turn to mud.
There is a little rubber stopper on a heater pipe at the back of the engine on the passenger side. You probably want to replace this after flushing the system just to be safe. (Its only like $4 from Toyota) Mine broke the day after I flushed my cooling system. Luckily I noticed it when it was only a pin sized hole, or it could have been a lot worse.
You will probably also have to replace the valve cover seals, the spark plug valley cover (its a gasket too), and the distributor O-ring at some point in time also to stop oil leaks.
There is a thread here somewhere that goes in depth about maintenance on our Supras. Ill see if I can find the link.
