7mge head bolts????
Supra-D.S.
Washougal
i cant find out if they are tourqe to yield bolts or not and i cant find them anywhere can anyone shine some light on this for me
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
There's no issue with re-using the stock bolts. Use them if you are going with a stock head gasket, just make sure you inspect them for damage, make sure the bolt holes are clean and aren't full of water, and coat the threads lightly with oil before putting them in and torqueing them.
87MK111Supra
San Diego
I had heard that they were yield and shouldn't be used twice. I reused stock bolts on a 7GE and they loosened up so I went with ARP bolts. I wouldn't get studs unless you are thinking of going turbo later on because they are a little overkill.
My 2 cents.
