Poodles;1424481 said:Ah, ok, then that's another thing. Also, isn't the oil dipstick in a different place?
IJ.;1424485 said:Nope it's the same, only different in a Cressida.
You sure IJ, I had to "tweak" mine to get it around the turbo.
dumbo;1424616 said:You sure IJ, I had to "tweak" mine to get it around the turbo.
slow_yota;1424633 said:Hmm, Ok.
i think i'll ditch the n/a cam idea then.
have to get some stock turbo or higher duration cams later.
I'll probably get the n/a motor for the build from the yard if i can't find one in the next week or two. Pulling it in mid November will be no fun. =/
I'm sure i'll be able to drill and tap some oil lines.
The KS's may be a lil different of a deal though.
Poodles;1424692 said:Better to just drill and tap the bosses. The oil feed bosses are going to be a LOT harder though and personally I'd just get a GTE block...
Also, yes, the dipstick tubes are different and the NA dipstick is shorter and of a different design than the turbo.
deabionni;1424819 said:Only the intake cam is different. The exhaust cams are the same.
If you wanted to get better breathing for your NA-T, all you'd hve to do is get a turbo intake cam.
Poodles;1425110 said:Beat me to it, though it doesn't show duration, it proves they have more lift.
