Oh, I was just seeing if you were still awake.
The pins inside the plug on the harness are split... you actually want to press them closed tighter as they slide around the pins in the Pro's receptacle. Just insert a small sewing pin on each side of the plug's pins... it doesn't take much, so don't over do it. Use a magnifying glass to take a good look at it and you'll see what needs done. Don't over do it though, crush them and the plug may not reconnect properly.
Back to this ACIS stuff.... well, I'll go ahead and log it and see what turns up. I'm not feeling so hot today (I better not be getting sick) so it'll have to wait for some other day. I'm also going to put a diode across the VSV's coil since I don't know if there is any such protection in place. I also need to check a setting on the Pro which is used to alter the TPS signal and make sure it's disabled.
