Hey guys i recently did valve cover gaskets,#3gasket,cleaned pcv tube on top,found about one inch of oil in spark plug valley,whoever worked on this last screwed up the 14 mm plugs,no sealant,crossthread,a mess,anyway got that fixed,now the front vent hoseunhooked it blew through it,it just makes a circle from crankcase to valve cover,my plan is to cut this hose use a 90 elbow pvc pipe with a filter on end pointed up so oil doesnt travel up it,on he pipe coming up from block going to do the same,put a filter on top of it to,as long as it breathes whats the problem,,it seems redundent to me,imeant pcv rubber hose instead of pvc elbow,as long as it can breath shouldnt be aproblem ,any thoughts,thanks,mmkkpro
