Hey all, so I finally got my car running again after a rebuild and NA-T swap. The car is now running crazy rich.
At first the idle was really high (probably 2500) but it would stay running and it was throwing Code 51 (throttle position sensor).
After calibrating the TPS, Code 51 went away untill i touch the gas, the idle went down significantly but wont stay running without touching the gas.
Pulled the plugs and all 6 were showing just how rich it was running not to mention the streak of soot sitting behind the car.
During the rebuild the factory 440cc injectors were cleaned and flow tested. The O2 sensor is new. I had a spare ECU so tried that and no change. Smoke tested the vacuum system, no leaks. Checked the wiring from the ecu to the tps and it had good continuity.
At this point I am a bit lost so any help would be greatly appreciated.
