IJ.;1891736 said:
2J everytime if you have the budget, 7M can but most won't
QFT.
500WHP is where it's borderline for cost on the 7M vs the JZ. where it costs a similar amount, both starting from stockish. 400WHP is (IMO) where the 7M is clearly more economical to get to, maybe 450 if you're careful.
Note, I have an '89. Mine does NOT have the round motor mounts. That changed part way through the model year, so it's '89.5+ that the JZ "just drops in." It's not the showstopper that it was, you can buy mounts for the older square motor mounts to the JZ blocks easy enough now.
For that goal, I'd be looking at doing a 1.5JZ, where you take a 2JZ block and put the 1JZ-GTE heads and electronics in. This gives you the compatibility of the 1JZ with the chassis along with the 3L displacement and the easier power that makes. Pop a nice single on that, and piggyback electronics. Or just go straight to the 2JZ-GTE and go stand-alone. (I wouldn't do that, because it would get hard to drive on the street before I was done. XD
I believe that the word I'm looking for is "Projectile.")
@KWITTS: Actually the JZA70 started production with the 1990 model year, but like the 7M, the wiring harness is different between '90 and '91-'92. It's also different for 1989, so if you have a 1989 chassis, you'll have some work to do to make the wiring work with the 1JZ wiring harness.
