Hey all, I will start by saying this is a STOCK 7M-GTE engine - and ran beautifully until this problem occurred.
After doing a pull in 2nd gear, I came to a stop and the engine was running rough as if it were some sort of vacuum leak or misfire.
Cut to the chase here... its a cam timing issue. I managed to remove the upper timing belt cover bolts and have a look inside. The belt is not broken, but it can be easily pushed down between the two cam gears. I have not had time to drain coolant, remove the waterneck and upper rad hose to fully get the upper cam gear cover off, but I can see the tensioner seems to be still in tact.
As well, I tried checking the timing with a timing light (yes with the jumper in place!), and I believe the timing is so far out I am unable to see any line at all. (I have done this in the past, and it WAS set to 10* BTDC with jumper in place).
Any ideas as to what would cause the timing to go out of wack, and the belt to go loose all of the sudden like this?
Your help is appreciated!
Thanks guys
Thanks guys
