Since I have a spare engine at hand I thought I might aswell build it.
So I decided I would make a list of what is needed so I can get a budget ready. The first list I'm making will be for stock and near-stock builds.
Bottom end (prices taken from toyodiy.com)
Have I missed anything? The list does seem a bit empty for a COMPLETE rebuild.
Code:
ALL TOYOTA, COMPLETE STOCK
Part Part-number Price (euros)
Bearing set, crankshaft 11704-43010 150,79
Bearing set, connection rod 13204-42010 112,31
Piston, ring set 13011-42010 158,65
Piston, w/PIN 13101-42080 89,56
Rod, connecting 13201-49045 120,38
Piston, hole snap for PIN 90521-25001 1,04
Washer set, crankshaft 11011-43010 29,54
Head gasket 11115-42020 80,00
Head bolts 90110-12002 3,77
TOTAL 746,04
TOTAL USD (GOOGLE CONVERSION) 1102,05
Code:
STOCK,
Part Part-number/link Price (USD)
ACL Bearing set (main, thrust, rod) Driftmotion 59,00
NPR Piston set (pistons, pins, rings) Driftmotion 120,00
Toyota Rods 13201-49045 180,00
ARP Head studs Driftmotion 119,95
ARP Main studs Driftmotion 109,00
ARP Rod bolt set Driftmotion 50,00
HKS MHG Bead 1,2mm Driftmotion 105,00
TOTAL 742,95
