Alright everyone I just took paart a '89 7M-Gte. The motor was perfect. Only the two end main caps had wear on the bearings. The crank has no issues. and the pistons came out with easy.
my question is, sense everything looked great, can I buy a new bearing set pistons, and use a " I think its called ball hone " and just put my cross hatching in and put new rings pistons bearing in throw it together with a stock Hg* and run it?
Or do I need machine anything? The head was great too. I would like to know your thoughts. Everything seemed great to me when i check everything, should I go ahead and do clearances?
Eathen
Eathen
