7m-gte 1jz help
2mtx12
4
fl
i dont know a lot about supra i been a chevy guy for years and i was looking at geting a mk3 and i need help what are the is specs
and is the 7m-gte and the 1jz the same if not what is difference
and what do the stock mk3 turbo supra run
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
welcome
7mgte 3 liter straigt 6 single turbo 83? mm bore, 91 mm stroke 6500 red line 232 hp 254 tq. runs low 15's known to go through head gaskets
1jz 2.5 liter straight 6 twin turbo 86mm bore 71 mm stroke 7200 red line 280 hp 270 tq.? runs low 14's know to go through stock twins
7m you can probably find parts more readily for.
have both love both. both very easily modified. hope that helps some
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
2mtx12 said:
so the 1jz is a better choice and what does a 1jz supra go for
1JZ is generally a more reliable motor. JZ-series (1JZ, and 2JZ) are known to be badass in lamest terms. If I had the choice of either a 7m or 1JZ i'd most likely go for the 1JZ. It supposedly to cost around $4k to $5k to do a complete running 1jz swap not including the car.
p5150
ASE and FAA A&P Certified
Central Idaho
1jz was available in Japan only - any 1J you see here in the states is the product of a swap or was a RHD car shipped here.
