7M-GE vs 7M-GTE
Poptart
14
Iowa
Okay, so my engine blew up...dont' know how, etc..but anyways
My parents will buy me another 7MGE, but not a 7MGTE, because they said that it probably won't fit in, blah blah..
I am saying, well...It is the same engine, just turbo...so I don't have to change out anything would I? It is a direct drop right?
But, I need to know if it is a direct drop, just a yes or no answer...
Now...if I were to get another 7MGE, and possible supercharge, would that be better than just getting a 7mgte?
Hmm, or what...I need a new engine ASAP, so I need to buy one on EBAY...
I just sold my truck, so I don't have a vehicle, so I have to walk to work and school (God what a walk..)
But please let me know, 7MGTE is a direct drop in right?
TobyCat
470
Vancouver BC
Definitely not a direct drop. There is a complete list of everything you'll need and a few options listed in the NA section.
NA-T FAQ
If you can find yourself a donor car of similar year, then it's doable...
lagged
1991 1JZ
new rochelle
Sl1dewaysSupra said:
Tranny and driveshaft, elecrtical, fuel and all sorts of little tedious things.
you should be made read only.
you can use the same tranny (and driveshaft) that your 7m GE used.
check out mkiiitech.com for other swap information.
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
Get another GE and then do a N/A-T conversion later on. That way you can get the car running ASAP as you stated that you needed.
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
It was my understanding that if you switched to the GTE you would need the R154. Or would you just need to swap clutch parts? Sorry if I gave out wrong info this was just my misunderstanding.
s383mmber1
3,614
Somers New York
Nope, W58 works with the turbo :)
Wouldn't even need to swap out clutch parts :)
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
You can use a w58 on a 7mgte no problem, it's just not going to be able to hold as much as the r154. so if you kept the w58 you could use the same driveshaft.
eric
lagged
1991 1JZ
new rochelle
dont post if you dont know.
cjsupra90
Jun 11, 2005
1,029
Lakeland, FL
I agree, but at the same time disagree. Had he not posted, he would still be under the wrong impression, so he knows the truth now, but at that same time if others that do know the truth had not seen it then someone else might be under that same wrong understanding. So I guess that its a win/win and a loose/loose situation all at the same time.
lagged
1991 1JZ
new rochelle
what i dont like is that when people like him post bullshit, other uninformed/misinformed members go on to perpetuate the OPs bullshit information.
if he was unsure of something, he should have searched (very likely, i know) or at least asked instead of passing it off as fact.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I would just suggest doing some searching. All the answers are here. You aren't the first person to attempt this so there is plenty of info out there.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
so i can use the turbo flywheel and clutch assembly with my w58?...im confused , because when i did my swap, i was told that using the w58 you needed to
use the nonturbo flywheel and clutch, and that came from drjonez.....:1zhelp:
loki2043
645
Portland, OR
no, you use the non turbo clutch and flywheel, because its a non turbo tranny, so you would just bolt it up to the 7mgte engine. but you are prolly better off going the na-t route.. unless you got a bunch of cash and time on your hands :D
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
thanks, because i was confused, one day i will get rid of my w58 for the r154......
