*7M Crank RPM Limit*
jdub
Feb 10, 2006
10,730
Valley of the Sun
IJ. said:
Update!
Turns out the bottom end isn't an issue with either crank!
I broke a valve spring :(
8000 sustained isn't the best idea!
What kind of springs you using Ian? Still Ferrera + retainers?
jdub
Feb 10, 2006
10,730
Valley of the Sun
IJ. said:
JaV: Try harder ;)
JD: Yep! :(
Looks like some of the inners were a bit tight in the outers and due to expansion it caused the outer to be nicked by a bucket....
Wow...that's the 1st time I've heard of a Ferrera spring failure :3d_frown:
Mine will easily go to 8500 when fresh just NOT for sustained periods like I've been running it....
Even then I'd be wanting to swap out valve springs every 2000>3000 KM's as a safety measure.
All well and good flashing a motor to 8+K holding it there is another matter entirely!
Not always, many times you'll wipe a bearing or suffer some mechanical damage during sustained high RPM running.
Having said that I've never heard of a Ferrera spring breaking before.......
(I'm sure it happens it's just not a common thing)
