I'm having the same problem as this and noticed that the port on the accordian hose that the PCV system links to has oil all around it, and the hose going to the PCV hardline is the same.
I was just gonna check those, didn't think to check the port on the TB! I'll check the entire system asap.
So cheers jdub, you've also pointed me in the right direction
