laotionracer101;1656849 said:Yeah i was thinking the same thing, im pretty sure he is getting them welded though but ive heard horror stories about this kind of thing,
Welds breaking off! DUN DUN DUNNN! :yikes:
Welds cannot break off on a welded camshaft. If I showed you two cams, one welded and one not. You could not tell which one is. The weld becomes part of the lobe and is re-ground to the same finish as a cast or billet cam. Welded cams are usually stronger than the original cam. The welding wire is a high quality steel, not a "chilled cast" like the oem. Also, the cams are heat treated after finishing.
