My engine is over 1000.
(no burn here) Admittedly, only for brief spurts - 9 seconds or 10 seconds at a time on a track, or a bit more on a dyno - you really can't consistently use that much power without getting tossed in jail. So, this isn't proof positive that the OEM bearings will take the load for any significant length of time, however it is a good indicator, and every mile of torture I put the engine through makes them shine a little bit more. Furthermore, while I'm working on proving the OEM units are ok for this level of power, I've not seen anyone put them to the test and have them *fail* at any power level. I'd be happy to see some evidence that they won't hold up - and that the failure was due to the bearing material, not lubrication.
I haven't posted anything about the auto swap, manual swap again or last dyno either.
Duane
