i have a few questions..
first, i bought a new Toyota oil pump ,and am doing a fresh ,somewhat stock, rebuild. with a turbo and supporting mods to make a little less than 500whp,should i shim the pump or should i be fine on the stock oil pressure?
secon, i need to know what size headgasket to buy. they took 0.006" off the block-deck and the head has been re-surfaced once and just had a finishing cut put on it.everything is prepped for a MHG ,and i need to know how thick to go to keep the crank/cam distances as close to stock
thanks in advance.
thanks in advance.
