Sorry guys, I've been really busy lately, and have not had much time here.
I ended up at 103 lbs on moly? Why, well it was really early in the morning when I was done with this motor, about 3am IIRC, and it's where I ended up.
I agree, looking back, it would have been better to have stayed at 85 to 90lbs on the moly lube.
The gasket on my engine is a Greddy metal one. (It's been in 4 motors so far, no leaks.)
I have been very careful about how it's removed, it was cut this last time between the tourqe plate and the block, and it's coated with brake quiet... (I know, a sin according to many, but if you have a bare metal head gasket, it works great. If you have one coated with a rubber coating, don't spray it down, just install it clean.)
On the question of the sealer, yes, there are a few bolts that go into the cooling jacket.. Make sure you use sealer on them, or you will get leaks. I found the sealer works so well, you don't need paper gaskets at all. Just a steady hand, and I like "The right stuff" it's like "Cheese wiz" only you are putting a nice perfect bead of sealant down, and you don't have to cramp your hand trying to get an even flow of it. Just depress the nozzle, and it flows out. Perfect every time.
BTW, the 103lbs has not seemed to cause any problems, but I have not broken anything in a very long while, and so I've not had this motor apart.. LOL
