Don't use the 6M if your going to build a high rev 7M.
(I'm talking up to 8500 rpm)
I did, and constantly broke off flex plate bolts,
not to mention welding the harmonic balancer to the crank nose.
I have done in 2 sets of ARP bolts, and one set of stock.
ARP suggested a stronger bolt,
but they want $100 per bolt & 3 months to do up customs.
So out comes the light weight 6M crank,
(as soon as I get the damn ballancer off)
and I have a ballanced 7M crank ready to go in.
I also dowel pinned the flex plate to the crank, to take some of the load off the bolts.
I may even loosen up the accumulator springs in the trans,
so that it allows a little more slip when it shifts.
I am getting real tired of dealing with this one weak point,
and don't want to shake another flex plate off.
By the way, anybody running an automatic as I am,
ARP has a shorter bolt than the 4AG ones that most Supra places sell.
It is p/n 254-2901, and is .800" long.
The 4AG bolts, p/n 203-2802 are 1.050" long,
and can only be used by bottom tapping the crank holes, and running the ATI flex plate (which is much thicker than the stock one).
