supralvr88;1273921 said:Spool is a joke with this. it takes till 4500 to get any real boost outta it.
it only pulled 354.89RWHP just a few hours ago at Boost Logic. I thought it was built with 400+ capability but it appears not. I'm not sure why it didn't put down more.
Something doesn't sound right about the 4500 spool. My buddy has the same setup and he's hitting full spool around 3800 - 3950. His profecb low mode is set to 14psi and the high mode is set to 18psi.
354 HP at 15psi is good power! Did you try more boost?
Can you post your dyno sheet?
