60-1, tD04,t04B
JNasty
i drive fast cars (supra)
Jun 25, 2005
358
Jacksonville fl
which one would be for more hp, and do you guys think is best?
with the t04b ar.60 (w/o wastgate)and tdo4 ar.60, i get the maniforld,50mm wast gate, and all the gaskets and bolts for a little more then the 60-1 build, not much more in price
to4b is polished
tdo4 is not
JNasty
Jun 25, 2005
358
Jacksonville fl
TO4B TURBO STAGE 5 with STAINLESS STEEL HEADER
SPECS:
a.. .60 - T COMPRESSOR WHEEL
b.. " STAGE V BRAND NEW "
T04 " P "
1.05 A/R TURBINE HOUSING
a.. COMPRESSOR HOUSING A/R .60 TO4E
b.. INDUCER 2.324" / MAJOR 3.00"
DESCRIPTION: SUPRA STAGE 3 TURBO KIT :TD04 TURBO CHARGER ,50 MM WASTEGATE
Td04 turbo, 50MM WASTEGATE ( 11 LBS SPRING RATE), STAINLESS STEEL TURBO MANIFOLD ( WITH WASTEGATE FLANGE, )
TD04 TURBO SPEC,WET FLOAT BEARING ,OIL COOLER,.60 A/R COMPRESSOR,
.67 TRIM
MDCmotorsports
Indy 500
www.MDCmotorsports.com
You're looking at an ebay junk pile aren't you?
Don't waste your time.
A true tdo4 is a small small turbo. A to4b or E can be as small as 42mm, wich is the same size as a stock CT-26.
Again, MAY I REPEAT MYSELF. Trim means nothing. You need to know the size of the wheel(s) in millimeters.
MDCmotorsports
Indy 500
Real t-70s are non existant.
An ebay t 70 is more like a t-????
They have around 63.5mm comp wheels.
Stop wasting your time with the ebay chinese turbos and buy a real garrett unit.
MDCmotorsports
Indy 500
Depends on your goals.
A 56mm compressor wheel will make up to 450/500 depending on how large the turbine and exhaust housing is.
You figure a sp67 (67mm comp wheel) is good to what around 700ish?
siman
Lifetime Ban
Murfreesboro, TN
Great way to put it Jon!
Trim means nothing really. Its all about the sheer SIZE of the compressor/exhaust turbines....they are the ones that is pushed and well...pushing...
the bigger the blades ( at the right angle) the more air they can push ( fluid dynamics....I.E. air is like a fluid).
So if you have a small exhaust housing but with a big exhaust turbine....its going to spool very quick...just because the exhaust is being pushed into a smaller housing with speeds UP the exhaust that hits the turbine....the larger exhaust turbine ( like a bike wheel ) the further it travels....
get me?
Thats why some T3/T4 turbo's acutally OUT PREFORM T4/T04 turbos...
the spool charectoristics are what you REALLY are looking for in a turbo.
Well...if your looking for flat out top end power....thats a completely different ballgame
Just put it this way: ITS BIGGER THAN STOCK
-Jonathan
8,898
Now there is really good advise. And sig material.
Maybe you need a TD06. Just about every turbo you change too will spool slower than stock. Differenc is, some are still pretty quick with response while having a broad powerband.
JNasty
Jun 25, 2005
358
Jacksonville fl
MDCmotorsports said:
If you want to go super budget, look into a holset hx35 or hy35. It will provide great spool (3-3300rpms full song) and make up to 500hp.
Did I mention they are cheap?
where can i find one
JNasty
Jun 25, 2005
358
Jacksonville fl
well its going to take me even longer now i have to build the motor (blew the hg) so im going to build it internally
