MDCmotorsports;924899 said:Go away NEWB. Please.
HAHAHAHAH!!!!!!!!!! well anyway, how far can you push the 57 trim.
Supracentral;924911 said:There are few things more entertaining than watching someone show up with knife to a gunfight. When seasoned turbo rebuilding professionals are posting based upon years of experience, scientific data and testing, and you show up and post about a chainsaws, you really look like a fucking moron....
/I'm just sayin'...
//You are the one that posted it
///Go away please...
////Love the slashies...
Cya;925117 said:MDC, what do you think of using an MR2 turbine housing?
IwantMKIII;923752 said:lol i can make 330+ on a tune and my stock CT at 12PSI.....
shaeff;925599 said:wait, what? i'm going to assume you mean crank HP, and NOT rwhp.
wiseco7mgt;925633 said:i have a friend thats running a 60-1 ct26 with the garrett cartridge on his turbo A , i believe he bought it from mike turbos in the u.s, can anyone shed any light if these have a longer life? do they run a bigger shaft?
MDCmotorsports;925770 said:Not really a bigger shaft, but a better thrust bearing assembly and oiling system for sure!
Should live, but then again you have a high flow wheel in a low flow compressor housing.
TheNewRed;926011 said:Well MDC what do you think of a 60-1 with an MR2 exhaust housing? When you mentioned welding the stock manifold you ment dividing the first three firing cylinders from the last three correct...i have a few books that contains some manifold building info ill check it out? Ialso have full access to UNOH's fab shop as that was the class i took last session, this could be a good deal!!!
wiseco7mgt;926050 said:thanks for the info:icon_bigg now how about the garrett cartridge and a 57 trim, anyone build that?
wardog;923635 said:Im no turbo expert but from the discusions that i have read about the ct26/60-1, 80% of the people are gonna tell u to go with the 57 trim. I personally have a ct26/60-1 on my car and made 350rwhp on 11psi . I had it rebuilt by majestic turbos of waco, tx 11 months ago and no signs of shaft play so far. If u want something that is not as big as the 60-1 or small as the 57trim a 60 trim falls righ in between them two but it is all up to you . There is a dyno of a 57 trim making aroung 420 rwhp with race gas and there is Jbl that made 455rwhp and 490ft/lbs or torque with a 60 trim ct and stock 440s. The cryo treatment should make the shaft stronger just like it does pistons and every other part that is cryo treated...
Quin;928705 said:No one else caught this? :bsflag:
FWIW, I've got a 62-1. I have a little compressor surge, and I'm assuming it's been run this way the whole time it's been in use. It's been at 15PSI for at least a thousand miles, still no shaft play.
