im about to install maft pro on my 7m i was wondering if any one knew where to get a 5v signal output for data logging on the ecu or if just buy a 5v restrictor diode and tap a 12v
Resistor is applicable only if you have constant and small current . What current you expect ?boosted2085;1294384 said:the vc is the tps..ill check it with the voltmeter..if not ill use the resistor
boosted2085;1294429 said:it said to run a 0-5v resistor off a 12v if the ecu doesnt have a 5v output...im running jaw(just another wideband)...if i use more than a 5v on the datalogger itll fry the microcontroller
