How is the trans...? How many runs on full boost... What rear gear ,and what oil are you running in the trans and diff..
Oh one more thing what clutch.. =)... that might be what is saving your trans right now... LOL
I cant belive that trans is holding up...
BTW the Cam/Crank signals are identical between 7M/2JZ/1JZ so almost any ecu will work for either setup... Just wiring... Only real difference is that 7M signals are week and might need the CPS regaped tighter to boost the signal... (voltage is exponentialy proportional to the sensor gap..)
