550cc Injectors with clips Great Deal
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
noah89t said:
denso 195500-2020 550cc high impedance injectors from the 91? turbo2 rx-7 fit our stock clips with minor filing. i got mine for about 25 a piece then had them flow tested. bypass the resistor pack
high impedance injectors dont run exactly the same as our Low impedance and the resistor pack. our injectors are paired and fired by only 3 channels, not 6. so, the stock setup is 3ohm + 3ohm +3 ohm for a total of 9 ohms at the injector driver, give or take.
technically, it could be anywhere from 4ohms to 7.6ohms for the paired injectors, add 3ohms for the resistor pack and you have a total of 7ohms to 10.6 ohms seen at the driver.
running high impedance injectors are 12ohm to 14ohm resistance. pair that up on our semi-batch fire system and youre getting over twice the resistance seen at the injector drivers in the ECU; 24ohm to 28ohms of resistance. im not electronics guru like ol' JetJock but im pretty sure thats not a good thing. im willing to bet that having too much current draw thru the injector drivers can cause a failure later on down the road. either in the harness, the ECU or the motor itself due to inadequate PWM signals.
noah89t
get naked & boost a supra
i have been running highs for about 4 years now and haven't noticed any problems. but i am not electronic guro either. i know of some others that are using the same ones i am and they have no problems either. i guess only more time will tell
the denso 195500-1370 are low impedance if you get the ones with the notch in the middle of where the clip goes.
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
yeah, i wouldnt say that the high's wont work. its just that i have no idea what would go wrong; ive never seen anyone run them long enough to find out.
the low impedance injectors are purple (when new) or Tan (when old) tops. the Red/pink ones are the high impedance injectors. ive managed to collect a full set of S4 T2 injectors, again. i let my other set go when i sold my 91 a few years ago. these are getting harder and harder to find now that everyone knows they exist.
cml61386
93
Buffalo, NY
What are these S4 T2 injectors? What are they out of?
MKIIINA
Destroyer of Turbos
Plano, TX
bigaaron said:
PTE on Ebay and Venom are the same! STAY AWAY FROM THOSE!!!
do what? the PTE's have a good record i thought. Ive been running them in my car for a few years now without issue?
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
i think the cutoff for the correct injectors is early 88 model year, or late 87 production date. someone once sent me a set of S4 injectors but had oval connenctors and they were not the correct ones but still had low impedance. IIRC, they were red tops too.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Look on the thread in SUpraforums, we are not the only ones who had big problems with PTE from ebay. We flow tested them and they were all waaaaay off, from 350cc up to 530cc, but not one was 550cc!
cml61386
93
Buffalo, NY
Sounds like with that results is they pretty much suck and for the people that have them with no problems got lucky.
gixxer750
2jzget comingsoon!
Mississippi
We have a set of these in a 300zx TT and they work quite well. The car is running 720cc injectors, two GT28RS's, forged internals, ported heads and an emanage. It hasn't blown up yet at up to 18 psi of boost.
