hottscennessey;1350651 said:Damn, impressive! Those GE cams are restricting you in the top end, but the jagged lines do look like retard due to knock, or possible ignition problems? It'd be interesting to retard base ignition timing and see if you can get the numbers to climb.
It's no 680whp or whatever ridiculous number you put down but it'll do
ihiryu;1350679 said:unfortunately the plenum doesn't bolt up, the only front facing intake manifold (FFIM) that is available is the FSMoto intake manifold, but that in itself is like a thousand.
Dok, I'm probably going to have to pass on e85 for now then, I figured there's no point to waste the money on big injectors if I plan to run stock ecu for awhile (need to save some pennies for now). 720's will still run on a stock 2jtt ecu with a SAFC, and that should get me into the 500 range.
DIY Autotune has 1000cc Delphi injectors for $59ea, if 720s will run on the stock ECU with regular gas it should run well with those on E85
frontierguy25;1350694 said:Wow!! Great numbers Josh!! Congrats!!
Now take that beast back to the track and post up a good number!
I will as soon as I save some money for a replacement diff and trans
:boink:supra87t/t4;1350803 said:Congrats! :thumbup:
Maybe I should get off my butt and finish mine...
