2543arvin;1674387 said:
Are you still running stock injectors? That would be my next purchase unless you forgot to mention them.
yeah thanks for calling that
i am planning on buying those next but i am not quite sure if i wanna go with 550s or if i should go bigger... i will be able to run 10 lbs on stock injectors untill then
---------- Post added at 06:44 PM ---------- Previous post was at 06:35 PM ----------
barkz;1674377 said:
So add these new toys youre getting, then if you still wanting more, get a MBC and turn it up a little...if you still want the bottle look into the Cry02 kit. C02 instead of nitrous, just to cool the air charge, which turbos like
unless i am mistaken the maft pro should work as a boost controller... and its not the "bottle look" i am going for increased spool time ... with this setup (and bigger injectors) my turbo should kick my ass but i want a faster launch lol i dont wanna "wait" thats why i am inquiring about nos
---------- Post added at 06:52 PM ---------- Previous post was at 06:44 PM ----------
NashMan;1674406 said:
if your a nobb at nos stuff just run a zex setup
zex tubo kit not reg kit or it will not regulate the fuel propley and just go hella rich at upper rpms
that sounds awesome and is exactly what i am looking for thanks
Edit: would i have to alter my tune to run the zex?? could the wet shot compensate properly for the tuning or would i have to richen my mixture ... if thats the case would running a "nos tune" cause a substantial over rich condition when i am not running nos??? or cause noticeable proformance issues??? and what about retarding my timing 2deg???
i see that it has a
" Unique nozzle design has Active Fuel Control™ built in. This feature monitors bottle pressure and
when the nitrous system is engaged, it adds or subtracts enrichment fuel so the engine never runs
too rich or too lean"
but does this mean that i can run it twice a week to once a month and not tax my engine??? or is that just a risk i would take running nos???
