i was wondering if a 50 trim ct26 is good for making reliable hp, how much hp would i expect to get from one adn how much should i pay for one with a fresh rebuild, with 0 miles on it.
Had my 60-1 for about 4 months I want to say and I haven't had any problems with it.bigaaron said:60-1 is too big for a ct26 housing if you want reliability. 57 trim seems to be the best for power and longevity. You can make around 375whp max with a 50 trim, and the spool is pretty fast. 57 trim spools almost the same and can make around 400whp, maybe a little more. All the threads from a while back about people blowing up their ct26 were all 60-1 iirc.
Is that with the core sent to you or with you using a spare?bigaaron said:I get em done for $525 including the return shipping. 50 trim up to 57 trim.
I can ceramic coat the exhaust housing too for an additional charge.
JustAnotherVictim said:Is that with the core sent to you or with you using a spare?
bigaaron said:...57 trim spools almost the same and can make around 400whp, maybe a little more....
