I figured it out! Go to the cruise control box and cut the black/white striped wire. Wire each half to a terminal on the switch at the top of the clutch pedal. Voila, you now have cruise control that cuts out when you press the clutch pedal.
jetjock;1059941 said:That's how the 5 speed comes wired from the factory. The auto is supposed to be wired through the NSW. Either way it's the same cancel input.
jetjock;1060045 said:Yes, when you went 5 speed did you jump the connector to get the engine to start? If so that would do it.
jetjock;1060051 said:Well, there you go. Shot yourself in the foot![]()
Btw I hoped you wired up the clutch safety switch too because you will crank that baby in gear someday. I guarantee it...
jetjock;1060072 said:Wise move. Think parking space with other cars nearby. Think garage. Think garage with buddy in front of car while you're both working on it. I never stand in front or back a car when it's being started, something I see a whole lot of people do. They be crazy...
spinningheadboy;1060456 said:http://www.supramania.com/forums/showthread.php?t=53498
I've done something similar a year ago. I kept my AT ECU and have cruise, cruise cancel from the clutch pedal, and clutch pedal safety start.
CWD
Nocheez;1060503 said:Bah! Why wasn't that thread in the FAQ section? I knew I wasn't the first to do this, I just wanted the information to be more easily accessible.
