BigSupe said:What does it raise the boost cut level to?
the boost cut level is determined by the ecu.... stock fuel cut on the jdm 2jzgte ecu is 15 psi
SirLoki said:the boost cut level is determined by the ecu.... stock fuel cut on the jdm 2jzgte ecu is 15 psi
Bondango said:Loki the Ausy soarer guys having been doing this mod for years, Jspec 440cc+2jz map, fuel cut is 18psi.
SirLoki said:my boost guage is probably off then.... old hks![]()
honestabe said:We all know what that means, an excuse to upgrade.![]()
that's what i've been hearing about that combo, but i have that same mod and still i'm hitting fuel cut around 1 bar.. how is it that you guys are hitting it at 16/18 psi?Bondango said:Loki the Ausy soarer guys having been doing this mod for years, Jspec 440cc+2jz map, fuel cut is 18psi.
slidingsidewayz said:that's what i've been hearing about that combo, but i have that same mod and still i'm hitting fuel cut around 1 bar.. how is it that you guys are hitting it at 16/18 psi?
masterchief819 said:I don't know how credible this is, but I was once told that injectors are good up to the hp of their cc. (i.e. 370cc good for around 370hp etc.)
Anyone wanna confirm or disprove this?
